why is this.i cant figure it out im using huffy codec and the captures are jumpy as hell like theyve been caped at 4 frames a secod or something
i am having the same problem (see my post "trouble capturing in winxp)
can some1 help us??!! -
try seeing what services are running, try stopping any you don't need...
Did you install with administrators rights? -
Is your capture app actually reporting dropped frames??
A HuffyUV encoded AVI will NOT playback smoothly on most computers. It will however, look just fine once you've converted it to MPEG.
mp4 capture appears distorted. Fine in quicktime. Screenshots on post
By flamy in forum Video ConversionReplies: 17Last Post: 29th Mar 2010, 11:22 -
Sony Video Capture 6 (Vegas MS) hard drive max size limit?
By distendo in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 12th Jun 2008, 09:02 -
Does simultaneous computer usage affect capture quality w/USB capture?
By miamicanes in forum Capturing and VCRReplies: 3Last Post: 19th Sep 2007, 18:05 -
Any Capture Card Still Run Under Win98?
By Ensign in forum Capturing and VCRReplies: 9Last Post: 17th Sep 2007, 12:16 -
4gb Limit on SDHC Card, FAT32
By AVCHD in forum Newbie / General discussionsReplies: 1Last Post: 13th Jul 2007, 04:24
