Results 1 to 9 of 9
  1. [size=18]I downloaded a movie that is a .mpg I want to convert it to a vcd. Can you guys help me decide which convert would be the best.[/size]
  2. umm just open your favorite cd burning app and select the mpg as the video source and the burning app will convert it for you
    here to help or express myself not to rack up my posts
  3. I don't have a fovorite burning app. This is my first time doing this. All of the link you guys have for converters, I see mpge and similar ones, but not mpg. Is there a difference?
  4. And aslo, we are buring it on our friends burnner, and the only options they have is to burn it as a data cd or an audio cd, which one should we use?
  5. nero or roxio has an auto vcd converter on them. Maybe telling us what your friend's burning software is would help
  6. you should try vcdeasy, it pretty good in converting to vcd . nero is good to but it will give you some problem if your file is not perfect. roxio is good aswell asfar as i have heard.
  7. Our friend uses an Easy CD Creator 4 by Adaptec. I don't really want to spend any money on buying any software, do you guys know of any freeware that might be good?
  8. Easy CD has VCD option? Lauch the project selector and choose VideoDisc I think
  9. Take it easy with the huge colored fonts (ah, I mean "fonts of color").
    As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
