I am wanting to make a backup version of Amelie and I was wonder what I would have to do to get the subtitles on the backup? I am using smart ripper but will use anything that will work.
For all of those who havent seen the movie you must see it. It is one of the best movies I have seen.![]()
It doesn't matter which ripper you use, the subtitle stream(s) is included in the VOBs. You need to use VobSub, VirtualDub or Avisynth to produce permenant subtile. Truman's guide has everything you need to know:
http://forum.vcdhelp.com/userguides/87065.php -
if you are going to make this back up to dvdr then you will need to rip the sibs with subrip, not sure what you are using to convert and re=author, but this guide should get you through everything, and when you get to the subtitles part make sure you use "the hard way" i have done this over 120 times and never had a bad subtitle stream http://www.doom9.org/mpg/ifoedit-cce.htm
Trouble ripping DVD with subtitles
By stig in forum DVD RippingReplies: 9Last Post: 22nd Feb 2012, 06:08 -
Subtitles ripping issues
By neo179neo in forum Blu-ray RippingReplies: 6Last Post: 7th May 2011, 07:24 -
Manually ripping subtitles from TV shows
By encodedprocess83 in forum SubtitleReplies: 5Last Post: 7th Oct 2009, 16:50 -
Ripping Foreign Subtitles in my PC
By devilcoelhodog in forum SubtitleReplies: 3Last Post: 23rd Feb 2009, 10:28 -
ripping subtitles from a movie?
By VanZan in forum SubtitleReplies: 3Last Post: 17th Aug 2007, 17:46
