    Aug 2002
    Argentina
    I know that this sounds crazy, anyway my problem is this:
    I´ve downloaded some movies, and the problem is that they are separated on 2 cds on vcd.
    and I need to use that movie in an personal video so, I want to edit it...
    so.. I don´t know how to do it.
    well, I need this ASAP.
    so any reply will be great..
    thanks a lot for your time !!!
    middlesex,england
    There will be a file called avseq01.dat (or similar) in the mpegav directory, copy this to your HD and rename as whatever1.mpg, do the same for CD2 and rename as whatever2.mpg, these are standard mpeg-1 files (providing it is a standard VCD). Import both into your favourite video editor join together and export as one avi. If you are using Adobe Premiere, you will need the Panasonic MPEG1 plugin (or similar and you may need to purchase this seperately). Simple!
