Hi!
I am ripping PAL DVDs with DVD2SVCD and i wonder wich of those i should use for best result: no deinterlacing, smart deinterlacing, Blendfields, separatefields\select every ,vertical redcueby2 or telecide.
"If you need a quick and dirty deinterlacing select SeparateFields/SelectEvery or VerticalReduceBy2. Telecide is a more thorough operation and will give you the best results. Smartdeinterlace and Blendfields are not really suggested."
http://www.doom9.net/mpg/dvd2svcd.htm
DiVX (AVI) to (S)VCD using DVD2SVCD
By LeeBear in forum User guidesReplies: 125Last Post: 4th Jul 2008, 18:01 -
Help Please, Error message while using DVD2SVCD and TMPGEnc 2.5
By FizzFozz in forum Newbie / General discussionsReplies: 1Last Post: 16th Apr 2008, 17:28 -
DVD2SVCD Vista compatibility
By Kibble in forum DVD RippingReplies: 5Last Post: 19th Mar 2008, 10:51 -
DVD2SVCD with CCESP 2.70 - CBR 6kbps? No way around?
By Colmino in forum Newbie / General discussionsReplies: 1Last Post: 6th Jan 2008, 01:48 -
AVI,DivX,XviD to DVD with switchable subs using DVD2SVCD
By Baldrick in forum User guidesReplies: 18Last Post: 6th Jul 2007, 17:08
