I am trying to Encode and Author a 100 minute DV video (from my Camcorder) into DVD.
I followed a TMPGEnc guide and created a high quaility template based on the default PAL DVD version (2pass VBR with a lot of maximum settings selected).
22 hours later, it finished encoding and I started the Authoring process.
I have found a problem with the mpeg, but don't know where to start debugging it.
1. PowerDVD.
If I play the MPEG under PowerDVD, it plays perfectly and the quality is fine. However if I grab the 'time-line' and drag it to the end of the video, when I let it go, the video only goes to a point 3/4 of thay way through and the time-line 'springs' back to about 3/4.
From here, dragging the timeline to the end does nothing except jump a few frames. Every time I drag it to the end and let it go, it springs back!
However, the video plays fine and I can fast-forwards it (at 32x) to the end.
2. DVDIt/MovieFactory
When I am playing the video under the authoring package, I get similar(ish) problems.. The first 3/4 of the video plays fine.. But when I drag the time-line towards the end of the video, it just stops.. The counter keep increasing, but it won't play.
Where ever I place the time-line, I get a still image, but when I hit play, the video doesn't move.
The strange thing is that if I 'author' the video and create a DVD, it plays fine on my Pioneer DVD player.. Its just a problem with my PC.
Perhaps its an issue with the MPEG codec that I am using for playback?
Results 1 to 1 of 1
Play from latest point
By spliffenheimer in forum Newbie / General discussionsReplies: 0Last Post: 10th Aug 2010, 11:54 -
Pinnacle Studio - Will not render past halfway point
By pooty13901 in forum Authoring (DVD)Replies: 4Last Post: 14th Jun 2008, 20:47 -
DVD Won't play past menu on laptop
By DVDLovers in forum Newbie / General discussionsReplies: 4Last Post: 11th Jan 2008, 12:24 -
Youtube .flv files quickly stop playing but will play past half way point
By video1312 in forum Software PlayingReplies: 1Last Post: 20th Sep 2007, 13:20 -
Can not play DVD's past the intros.
By joeuu in forum DVD & Blu-ray RecordersReplies: 5Last Post: 17th Aug 2007, 10:06
