Hello owners of Pioneer A04!
Can you select the 2x option for DVD burning in Nero WITHOUT having a DVD-R in the drive?
Does Nero first check the disc and THEN let you choose burning speed?
Guest
Yes, only if your media has been detected as 2x compatible and NO, if it can only do 1x.
Hello,
Yes you can select between 1x or 2x wrting within Nero.
However, this is not possible it you have ASPI 4.60.
Upgrade to ASPI 4.71 and you can select the writing speed.
Using Nero 5.5.9.0. and ASPI 4.71 myself, I can select between 1x or 2x writing.
Why this is, dunno !
Greetz,
The Doc -
I hate to sound dumb but I am so frustrated with my HP200i I can't think straight. Where did you get the update for the ASPI layer?
No. All this update will give you is the ability to select a 2X burn option IF the DVD-R is capable of burning at 2X. DVD-RW disks are always going to burn at 1X - no matter what you do.is the x2 update for both DVD-r & DVD-rw?
what colorspace to select in Lagarith ?
By codemaster in forum EditingReplies: 1Last Post: 1st Jan 2012, 10:44 -
what to select in coreavc at deinterlacing
By digitalray in forum Newbie / General discussionsReplies: 2Last Post: 13th Jun 2010, 21:58 -
How to quickly select pictures?
By coody in forum EditingReplies: 5Last Post: 27th Nov 2008, 23:10 -
Help with Pioneer DVD Writer DVR-112D and Nero
By tdoran70 in forum DVD & Blu-ray WritersReplies: 6Last Post: 1st Sep 2008, 17:23 -
Illegal Disc Error w/Pioneer DVR-105 in Nero
By Quadzilla in forum DVD & Blu-ray WritersReplies: 2Last Post: 20th Aug 2007, 13:23
