hi, i did a search on this but i didnt quite understand what it was since none of the posts explained what it was - they just reffered to it.
what is "seconds per key frame" exactly ? thanks
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
A keyframe is a marked point at which point an event will take place.
The seconds part of the statement refers to the timing of the keyframe.
This is genrally used in Flash compositions and in more advanced video editing in Premiere when you what to overlay roll on roll off graphics over the top of a video clip. You have to set the Keyframe for the start (normally automatic obviously), at which point you want it to start rotating, one keyframe, when you want it to stop, second keyframe, and how long you want it to rotate for.
Does this help - difficult to put into words.
Avidemux: The beginning frame is not a key frame. Please move the A marker
By devilcoelhodog in forum EditingReplies: 13Last Post: 8th Jun 2015, 12:38 -
Key frame editing?
By vato76 in forum EditingReplies: 3Last Post: 7th Jun 2011, 12:55 -
How to cut xvid avi by a non-key frame
By Kirill in forum Newbie / General discussionsReplies: 2Last Post: 2nd Aug 2010, 06:52 -
configure XVID so virtualdub key I-frame's is able to go 1,2,3,4,...?
By Ghtpua in forum EditingReplies: 0Last Post: 21st Oct 2007, 14:05 -
Virtualdub: the key frame displayed is off
By cheerful in forum Newbie / General discussionsReplies: 11Last Post: 19th Jun 2007, 12:28
