  1. I read that one of the problems toast has with burning a VIDEO_TS folder, is that the volume you are filling is less than 4.3, and toast has a problem with this. How do you guys get toast to believe that the DVD you want to burn is 4.3? Do you just fill a folder with crap until you get to capacity and throw that folder onto the disk also just so toast will think the disk is 4.3 of useable stuff?
    Thanks,
  2. I've never had a problem with Toast Titanium in writing DVD's of any size. You don't need to add extra junk... Are you running the latest version? I have OS X if that matters.
  3. Yes, I have latest versions of OSX and Toast. I am having a conflit. you can read my other posts to to see what my conflicts are if you would like to. This filling up was just one suggesstion I received. I just really don't want to re-install my system software.
    Thanks,
