I have a Compaq 730US Laptop and it has a DVD player in it. I use my other computer to make a DVD and it playes fine in my DVD player hooked to my TV But it wont work in my laptop. I am using a DVD-RW for a trial.any help would be Great.
Zoolo
Results 1 to 11 of 11
just a though but is the dvd in your laptop compatable with dvd-rw or is it some only dvd-ram/rom thing ..
dont know how do i tell if it is DVD-rw compatible.I just bought it about 3 weeks ago.
says nope on this page http://www.dvdplusrw.org/resources/compatibilitylist_dvdrom.html
i looked up the model number of what you have, which is a dvd-rom ... and that dvd-rom (some can) cant read dvd-rw -
that sight you linked said it was for DVD+RW and DVD+R. it doesnt say anything about DVD-RW and DVD-r.
IF this helps at all the DVD-rom drive is a Toshiba MD#SD-C2502.this is what is in this compaq.
Maybe this is too simple, but have you installed DVD player software ? It might be supplied seperately in the compaq box, or not be supplied at all.
does the drive recognise the DVD ? If not, then forget it. -
no it doesnt recognize the DVD. i used nero to burn it. but it does recognize the dvd-r that i made from pinnacle express. but it doesnt play it very smooth at all it is all choppy
hmmm...maybe the drive isn't very good at reading the type of dvd-r/rw's you are using...try a dvd player where you can set the buffer...
is dma transfer enabled on the dvd player ?
what if you copy the files ti your hdd...does it play well then ?
If from hdd playback is still choppy...the problem lies in creation of the dvd...if it plays wel on a standalone it must be some compaq driver/codec problem.. does it play original dvd's smooth ?
the player is exchangable...try one of a friend to see if it's a drive problem. A new firmware (if availbale) may help. -
well i couldnt get it to read a DVD-RW but i did get it to play a DVD-R perfectly.thnx for all the replys.
Zoolo -
Did you close the DVD or leave it open? Many DVD readers, for
whatever reason, cant initilize an open DVD... Just a thought though
its a long shot but a thought...
Good luck
VHS to DVD recorder wont play on computer!
By topgun68 in forum DVD & Blu-ray RecordersReplies: 11Last Post: 3rd Nov 2008, 15:56 -
home made DVDs wont play on all stand alone DVD players. why?
By suomiaussie in forum Authoring (DVD)Replies: 12Last Post: 2nd Jan 2008, 21:59 -
Toshiba SD1200; wont play reg 3 dvds
By Rabu_xiah in forum DVD & Blu-ray PlayersReplies: 4Last Post: 14th Nov 2007, 11:18 -
Why wont windows media player play any audio from my created dvds
By thnkbg in forum Authoring (DVD)Replies: 1Last Post: 17th Aug 2007, 11:30 -
Copied dvds wont play on my PC
By Rgalan in forum Newbie / General discussionsReplies: 10Last Post: 21st May 2007, 17:34
