8) Can someone give me step by step instructions on how to create a VCD with the proper settings (The best quality you can get out of it) from start to finish (burning onto cd-r). It doesn't have to be too detailed. I'm sure many of you could do this in you sleep....so help a guy out!
I'd really appreciate it!
I'm trying to convert an .avi file to be compatible for VCD.
I'm using TMPGEnc plus 2.5 and Nero.
um... if you havnt noticed, this whole site is about vcds (and svcds, xvcds, dvds, etc.)
you need to look in the how to section...
itll tell you everything you need to know.
Installation/Uninstallation instructions
By Jirka Cech in forum ffmpegX general discussionReplies: 57Last Post: 24th Apr 2012, 17:45 -
Making a VCD to send to the Philippines
By StrikerZERO in forum Authoring (VCD/SVCD)Replies: 17Last Post: 7th Dec 2010, 10:11 -
Instructions for DVDShrink with ImgBurn?
By JohnnyBob in forum DVD RippingReplies: 29Last Post: 9th Sep 2010, 16:00 -
Need instructions on how to use avi.net
By snafubaby in forum DVD RippingReplies: 1Last Post: 21st Dec 2008, 19:05 -
Making VCD Copy
By audiophile in forum Authoring (VCD/SVCD)Replies: 5Last Post: 18th Sep 2007, 08:20
