hi, i have been burning/making vcds for some time, but i have noticed recently that when i try to burn some mpgs to vcd, nero will tell me that it is not proper encoding for vcd, although it plays fine on my pc... i usually just click 'ok' and let nero do its (timely) re-encode. then the vcd will burn and when i try to watch it on my standalone dvdplayer (or pc dvdplayer) the audio is out of synch... and it gets worse as the movie goes on. any ideas? ive tried the mpg->mpg conversion in vcdgear, but to no avail. im totally stumped on this one. any help would be appriciated.
thanks,
catch
btw- using WinME (i know, i know... its my uncles pc), 1.1ghz, 256mb, 20gb HD, 12xburner .. also using nero v5.5.8.2
Although I can not answer your question I am having the same problem. I am using XP Pro. Each time I go to burn I get the message turn off compliance or let Nero re-encode.
Hey, i got it all figured out.. THANK YOU SO MUCH and MAD PROPS to Scudster and dreamss of #vcdhelp on EFnet
Optimus, you need to demux and remux with TMPGenc, feel free to email me at catch2wenty2@yahoo.com & i'll give you instructions, or msg me on EFnet (catch22)
Nero Vision (edit:) Motion Adaptive Frame Rate Conversion
By sagat93 in forum Authoring (DVD)Replies: 12Last Post: 3rd Mar 2010, 11:06 -
AGK conversion problems
By loninappleton in forum SubtitleReplies: 10Last Post: 9th Sep 2009, 10:48 -
Conversion problems
By djtommye in forum DVD RippingReplies: 8Last Post: 16th Oct 2008, 02:13 -
VC-1 Conversion Problems
By UHD4096P in forum Blu-ray RippingReplies: 3Last Post: 23rd Aug 2008, 00:40 -
avi conversion problems
By olson311dude in forum Video ConversionReplies: 14Last Post: 9th Oct 2007, 04:27
