    Nov 2001
    squeed
    Any chance ffmpegx will offer a direct convert to .MOV format ?
    -S
  2. hum.. what u would like to do? as Quicktime player is already able to open almost everything and convert to .MOV
    Nov 2001
    squeed
    Major,
    I don't have QT 6 yet, I am running QT 5 Pro. My thought was that if you could incorporate a QT conversion that I could skip a few steps on my quest to create a SVCD.
    Actually it would be great if ffmpegx could just go from a .VOB to a .MPG-2 SVCD compatible file. So then all that I would need to do would be to run Missing Tools to create a .XML file, create the .IMG files then burn.
    What do you think ?
    Also, are you going to include documentation on the next version ?
    -S
  4. For VOB to MPG2 you can already use MediaPipe, which has been recently Altivec-optimized.
    Yes I should include documentation in 0.0.3.. looking for some free time to complete it.
