Okay now I see those double sided DVD-R's with 4.7GB on each side.But that's like putting the movie on two DVD-R's,only you don't have to worry about loseing the second one.
Anyone know about 9.4GB single sided DVD-R's?
Since the dual-layer, single-sided DVDs made today are pressed, not burned, first they will have to make a DVD burner that can write to 2 layers at a (slightly) different distance.
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
New to double sided dvd's - Burning Hi Quality Media Files
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 7Last Post: 27th Apr 2012, 21:50 -
Double-Sided, Dual-Layer DVD media?
By dgpretzel in forum MediaReplies: 22Last Post: 15th Apr 2008, 16:03 -
Dual-Layer Double-Sided DVD's turnover?
By Deisel Weisel in forum DVD & Blu-ray RecordersReplies: 6Last Post: 22nd Nov 2007, 22:23 -
do they sell double sided, single layer dvd's (DVD-10 - the ones you flip)?
By cduval04 in forum Newbie / General discussionsReplies: 12Last Post: 24th Oct 2007, 11:40 -
How do I convert double sided dvd to dual layer dvd?
By acid_burn in forum DVD RippingReplies: 2Last Post: 22nd May 2007, 05:04
