Hello !
I try to create Mpeg1 video with TMPEGENC CQ rate control mode. This video would be authored on a DVD-R and played on a DVD Player. Do I need to change the VBV buffer size or leave it on 40kB. Is the VBV buffer size connected with frame size or bit rate?
Thanks, D.D.G.
If you want to strictly follow dvd specs then for mpeg1 you have to set:
- CBR
- 352x240 (NTSC) or 352x288 (PAL)
- Buffer size max. 327 689 bits (= 40 KB in Tmpeg)
- 4:3
- GOP max. 18 frames (NTSC) or 15 frames (PAL)
- Audio 48 kHz ac3 (NTSC, PAL) and 48 kHz mp2 (PAL) ...
regards
mb1 -
Hello!
Thanks for your reply.
The Mpeg1 clip authorized to DVD-R was jerky, and then the DVD player stopped, even i strictly followed the VCD specs ( the automatic VBV setting was worse).
But i found out what satisfy my demand. I encoded the video in mpeg2 352x288 non-interlaced (Pal) CQ70, VBV 224kB and the result is very good. One DVD-R can hold up to 8-10 hours of video (for example archiving).
Regards, D.D.G. -
But Mpeg2 with 352x288 is out of DVD specs ...
So you could have problems on other players ...
Edit:
No stop, it is inside specs, sorry.
But I would prefer at least 352x576 for better quality
regards
mb1
DVD Lab Pro Error: "Read data size is over the buffer limit"
By Motinha in forum Newbie / General discussionsReplies: 0Last Post: 29th Oct 2010, 03:49 -
What is buffer size?
By dzsoul in forum Newbie / General discussionsReplies: 1Last Post: 6th Dec 2009, 10:04 -
buffer size 25000 in ripbot
By miss in forum Video ConversionReplies: 7Last Post: 4th Sep 2009, 10:07 -
buffer size question
By socalkev in forum Newbie / General discussionsReplies: 0Last Post: 26th Sep 2008, 17:36 -
[ERR] GOP size is over the buffer limit - Compiling in DVD-lab PRO 2.30
By Wolverene in forum Authoring (DVD)Replies: 7Last Post: 31st Aug 2007, 23:55
