Is there any way that I can link or merge together end to end, several M-Peg clips so that they are infact 1. I wish to veiw the clips as 1 large one , from a cd using windows media player. The problem is that at the moment i have to start each clip in turn when the previous one finishes. If I could make one large clip and then burn it onto a cd, I could play the whole lot in one go. Where am I going wrong??? Cheers for any help you lot out there might be able to provide.
You can join them using the merge and cut option in TMPGEnc. Although you can create a playlist in windows media player. Open media player, click file-open then hold the ctrl button and click on all the file you want to play. They will then be played in sequence.
Craig
Export HDV clips to SD clips from Premiere Pro CS3
By foochuck in forum EditingReplies: 10Last Post: 8th Jun 2010, 17:03 -
link together
By linkinparkfrk123 in forum Newbie / General discussionsReplies: 1Last Post: 3rd Sep 2007, 19:16 -
Quiz Link
By ZAPPER in forum Off topicReplies: 8Last Post: 16th Aug 2007, 17:48 -
D-Link can't do it
By sue1951 in forum ComputerReplies: 4Last Post: 14th Aug 2007, 10:27 -
Such thing as dual link to single link DVI-D cable?
By Mizkreant in forum DVB / IPTVReplies: 1Last Post: 14th Jul 2007, 05:51
