All I'm wanting to do is to capture my VHS family videos to disks.
Is there really much clarity advantage in burning DVD as opposed to SVCD(or even fast bitrate VCD)??
Keeping in mind I have no interest in chaptering, etc....what advantages are there in doing DVD over the others, please.
thank you
(I guess I need to be educated)
Well as your source is only VHS I would say no, apart from the amount of video you could get on one disc.
Craig -
That's kind of what my experimenting is showing me.
I've got a DVD burner with Veritas burning software that will burn any files I want to put on the DVD disk. Even VCD and SVCD videos.
So, I think I can put a huge amount of "time" onto a disk in non-DVD format, but still take advantage of the 4.7Gig disk size.
And have an APEX AD-1100W player(along with all my relatives)that will play anything you can burn. So I guess I may be able to put maybe 4 1/2 hrs of copied video onto one disk.
Has anybody done that? -
The key advantage of DVD vs SVCD is the higher maximum bitrate.
SVCD would look much better (especially in high motion scenes) if you could use the same average bitrate (2.3Mbps) but have a maximum bitrate of 4+Mbps.
(I guess you can make a non standard SVCD for that though). -
S-VCD gives a nice quality if you don't want to enlarge or watch on large screen television. DVD has a higher maximum bitrate for fast moving video. This high bitrate can be used for s-vcd also, but an ordinary cd cannot be read that fast.
Bottom line, if the source permits it and is good enough make a DVD.
Want more movie on the disk. lower the bitrate = less quality.
DVD style disc can be read in almost any dvd player.
S-VCD or VCD on DVD disk gives some compatibility problems, and is basically the same as DVD in a lower bitrate.
DVD has a higher resolution/detail...
In ten years high definition television may show the difference in quality...you cannot do it over then
Good SVCD quality takes up 800 MB for almost 30 minutes of video.
Source DVD/DV make a DVD....otherwise SVCD is good enough. -
VHS SOURCE and/or ANALOG (INTERLACED) TV = SVCD
COMPUTER PLAYBACK and/or HDTV = DVD
Basically, if you have an SVCD encoded well, with a decent VBR or enough bitrate, it looks like DVD on a standard TV (I don't notice any difference at all, frankly).
To me, it's as simple as noticing that CD-R's cost mere pennies, while DVD-R's cost $$$$$$$$$$
Taking advantage of CUDA
By Danneauxsvh in forum Video ConversionReplies: 15Last Post: 14th Oct 2011, 05:31 -
How Can I Take Advantage Of My New Graphics Card?
By jg84 in forum Newbie / General discussionsReplies: 17Last Post: 15th Mar 2011, 13:17 -
AVI to DVD, advantage or disadvantage?
By coxanhvn in forum Newbie / General discussionsReplies: 3Last Post: 25th Jul 2010, 18:12 -
VCD to DVD (not SVCD)
By noyou in forum SVCD2DVD & VOB2MPGReplies: 20Last Post: 19th May 2009, 17:56 -
What is the advantage of getting a macrovision free DVD player?
By coody in forum DVD & Blu-ray PlayersReplies: 2Last Post: 8th Oct 2007, 23:33
