I was wondering if its possible to convert a music video i made which is in divx avi, and has a 320 x 240 resolution to a format which can be played on a dvd player. I've tried using TMPGenc to convert it to a a mpeg 1 vcd but when i put it in my dvd player it said there was a disk error. ( my dvd player can play vcd's) Does the audio have to be in a certain format because in the music video its a mp3 file? Maybe wav? Does the resoluton make it not work? Well i dont know. Thanks
Read the how to convert divx to VCD guide on this site (if the audio is compressed it has to be extracted to a wav file). You say your player can play VCD's but can it play CDR's
Craig -
When you use TMPGEnc, "load" a VCD template, there are 2 one for PAL and one for NTSC. This will set the output .mpg to the correct compliant settings. It does not matter if your source has a MP3, TMPGEnc will convert video and audio to the correct specOriginally Posted by ps2gamer4000
The quality of the disk is also important, if you don't know what your player can play yet, you need to experiment. -
If the source audio is a vbr mp3 there may be sync problems if you dont save it as a wav file first.
Craig -
Originally Posted by craigtuckerI was wondering if its possible to convert a music video i made
An easy way to make shure your dvd player can read vcds is by writing your video with nero express (www.nero.com for demo). It will automaticly encode the video at the required resolution, but it only works if your file is a .avi or a .mpg. If it still doesn't work after you write it's probably that your dvd-r doesn't read vcds.
VCD for ntsc has a set resolution of 352x240, so if you are loading a vcd template it will be resized to this resolution.
Craig
Avi to (MPEG1, MPEG2 PS)
By kilee in forum ffmpegX general discussionReplies: 7Last Post: 27th Dec 2010, 19:39 -
Why does XVID avi file balloon in size when converting to mpeg2 or dvd?
By im2020 in forum Video ConversionReplies: 3Last Post: 11th Aug 2010, 13:30 -
Converting MPEG2 Audio from AC3 to MPEG1 Layer 2
By jrisch in forum Video ConversionReplies: 8Last Post: 8th Dec 2009, 21:28 -
converting Dv-Avi/Dvd Mpeg2 to Xvid format
By glenpinn in forum Video ConversionReplies: 56Last Post: 9th Jun 2009, 10:23 -
Newbie questions on converting avi to mpeg2 and dvd authoring
By mlcampbe in forum Newbie / General discussionsReplies: 3Last Post: 4th Mar 2008, 14:08
