Running tmpgenc to convert *.d2v file and video file is coming up as unsupported. Have DirectX 8.1, and Divx codecs 3 and 4 loaded also. Tmpgenc.vfp is in the correct folder too. Please help.
-= kdlinms =-
Look in Tmpeg enviramental settings. Under the Vfapi entry is DVD2AVI project serving checked and showing Vfapi plugin?
I've had the problem of not being to open file types in Tmpeg but they were .m2v or .vob files. That turned out to be a problem in the windows registry. Another program was controlling the extensions. In my case restoring the registry to a previous version solved the problem. Do you have any other programs on your computer that can open .d2v files?
for m2v files make sure you have the svcd plugin otherwise youll get the usopported file format error you can find it in the tools section
here to help or express myself not to rack up my posts -
It's been a while and I've had to reformat my computer since I've learned to do this. While searching for the answer to this before, I found it but not this time.
I am running Win2K Pro on an AMD 1.2 gHz machine with 256 meg RAM and 100 gig of HD space. I am having the same problem as before, and tried all the codecs except for one(avi-divx_codec...due to an error received during installation...unknown what the error is) and still coming up with the same problem.
No other program will run the .d2v file the DVD2AVI has created. I tried redoing the rip from SmartRipper and the DVD2AVI again, but still to no avail.
Any help would be appreciated. Thanks-= kdlinms =-
Unsupported audio format in MKV file on LG 47LW5600 TV.
By kmplsv in forum Video ConversionReplies: 5Last Post: 23rd Feb 2012, 10:03 -
Unsupported format or damaged file -> ?
By ermetekos in forum EditingReplies: 1Last Post: 31st Mar 2010, 12:56 -
Unsupported FLV codec or format
By lovyagin in forum EditingReplies: 25Last Post: 12th Dec 2008, 00:13 -
Premiere 6.5 - unsupported compression format.
By vodmare in forum EditingReplies: 3Last Post: 28th Jan 2008, 17:51 -
cannot open or unsupported file on tmpgenc
By Donna Stefani in forum Video ConversionReplies: 6Last Post: 15th Aug 2007, 21:31
