Hi i have scooby doo which i downloaded as a svcd, i want to convert it to vcd but i can not do it. Iam pretty godd when i come to converting but this has my stumped.
I have tried every thing.
Please can some one help
use flashmpeg to convert,i could only convert cd1 from svcd to vcd using tmpge.......
I say use TMPGEnc and follow the wizard it won't take any longer than an hour.
Only an hour? Not unless he uses fastest quality (poor) and has a fast computer.
Copy the SVCD MPG file to your Hard Drive (if you have it in BIN format use CDMage and extract the MPG from there or use VCD Gear). Load up the MPG into TMPGEnc, load up the VCD template (don't use the wizard). Goto Settings, change quality to High or Highest. Start encoding. Repeat for disc 2.
Problems converting AVI to vcd format using TMPGenc 2.5 Plus
By peterock in forum Video ConversionReplies: 2Last Post: 28th Dec 2008, 16:34 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54 -
Problems Converting AVI to SVCD
By wiseguy109 in forum Video ConversionReplies: 3Last Post: 6th Oct 2007, 15:17 -
error encoding while converting avi to svcd
By joannekhow in forum ffmpegX general discussionReplies: 4Last Post: 1st Oct 2007, 12:41 -
Burning SVCD to a DVD (Not converting!)
By bebopdeluxe in forum Newbie / General discussionsReplies: 4Last Post: 2nd Aug 2007, 10:06
