Hi, I'm very new to using adobe premiere. I've been getting quite decent at figuring out how to edit video on my own. However I have one problem. I got an ATI TV Wonder PCI and it allows me to import clips directly as VCD MPEG clips. Now as I'm trying to edit our movie, premiere seems only to be able to export the video as an AVI or some other source. Obviously I don't want that. I really don't want to have to convert it to AVI and have the already compressed file converted again back to MPEG. That would just kill quality and take time. Is there a way for it to just keep the MPEG quality or what?
Well, I have exactly the same problem, I have and ATI all in wonder, and encode mpeg1 and mpeg2, to my saqtisfaction. You can render your work using the caracteristic export to web. There exist a program that export in diferent formats. This is CleanerEZ, when you descuber wil thing you are saved, but are wrong. The program takes many time to render and pass to the same format, fps, size, etc. that you have in your source files; and the result is poor, the image in the movie very bad.
Maybe I don't have probe enough. Anyway I'm looking somekind of plugin that workes better than CleanerEz
How Do I export VIdeo FIle Correctly In Womble MPEG Viedo Wizard DVD?
By V Bot in forum Video ConversionReplies: 4Last Post: 19th Sep 2010, 10:17 -
Premiere Export Always Blurry
By helloitsdan in forum EditingReplies: 2Last Post: 23rd Jan 2010, 09:40 -
Crop video on premiere cs4 and export as flv
By v1p0n3 in forum EditingReplies: 2Last Post: 27th May 2009, 15:07 -
Video corruption when trying to convert MPEG-2 to DVD-compliant
By DB83 in forum Video ConversionReplies: 2Last Post: 31st Jan 2008, 20:00 -
Youtube video: Premiere pro export and then use Windows Movie Maker?
By vid83 in forum Newbie / General discussionsReplies: 2Last Post: 13th Dec 2007, 22:59
