have any of you guys had any problems burning a vcd with nero on xp pro . cause i cannot get it to work ive managed to convert ok with tmpgenc andf it plays on pc but it wont burn just keep getting error messages in the burn window and it just aborts it please help im going nuts! lol
I use nero 5.5.8.0 with XP pro, without any problems. Do you have any other burning software installed. Make sure explorer is closed as that also uses the burning engine for burning to cd from within explorer. I think this only effects nero if explorer is open when you start nero though.
Craig -
ye i came across the problem with explorer but i sussed that one lol.
I can open nero without any problems its only when i come to burn it that i get problems it even scans it ok!.
Ive tried uninstalling and re installing with a newer version but with no luck , the latest thing it tells me is that it cant write to more than one recorder ! ive only got one recorder!lol -
I've got XP Pro and I use Nero 5.5.9.0. It works perfectly and all, but I really don't trust the VCD wizard that comes with it. Instead, I use VCDEasy to make the BIN/CUE file and then I burn the image with Nero. (I have a TDK veloCD which doesn't work with VCDEasy's drivers)
Hope that somewhat helps.Põtåtõ §ålåÐ -
oh well guys i suppose i must have a writer problem i just tried writing it as an iso and it still dont work
Intensity Pro firmware update problem on windows 7 pro 64Bit
By ulva in forum EditingReplies: 1Last Post: 5th Oct 2011, 08:00 -
VOB2MPG Pro / Win 7 Pro 64-bit Service Pack 1 Problem?
By Rich_A in forum SVCD2DVD & VOB2MPGReplies: 21Last Post: 2nd May 2011, 16:06 -
Corel VideoStudio Pro X3 and ATI TV Tuner Pro 650 Card Compatibility
By waldodiodio in forum Newbie / General discussionsReplies: 1Last Post: 27th Oct 2010, 13:41 -
Import Premier Pro 1.5 Project into Final Cut Pro/Studio 3 - how please?
By rjamesd05 in forum MacReplies: 1Last Post: 6th Sep 2010, 14:50 -
Editing Nero made DVDs: DVDauthorgui? dvd lab pro? Gui4dvdauthor?
By KneeRow in forum Authoring (DVD)Replies: 31Last Post: 22nd Aug 2007, 02:41
