i am trying to re-encode a divx file to mpeg 1 with TMPGenc but when i conert it the picture is fine but there is no sound what am i doing wrong or is there a better encoding program for the job.
First make sure you have the Audio codec, install the Nimo codec pack, it has most.Originally Posted by robbos_1999
Next in TMPGENc
Select options > environmental settings
click the VFAPI plug-in tab
right click the "DirectShow" and select higher priority, do this several times until its at the top with a value of 4
If that's no help, when you load it into Vdub, select File > File information what does it tell you about the audio ?
You may need to save out the audio to be used later with TMPGEnc
You may also need Vdub AC3
http://www.digital-digest.com/dvd/downloads/virtualdub.html -
watch out though had to build the whole file in tmpeng then cut into the desired sizes to avoid audio miss sync
TMPGEnc 4 Divx Setting
By Anakin in forum Video ConversionReplies: 2Last Post: 14th Oct 2009, 17:21 -
DVB-S MPEG -> DivX
By geohei in forum Video ConversionReplies: 8Last Post: 11th Oct 2008, 12:11 -
Firewire to divx/mpeg-4
By exon in forum Capturing and VCRReplies: 3Last Post: 2nd Sep 2008, 20:59 -
I have a problem with TMPGEnc 3.0 with DivX...
By blasedeviant in forum Video ConversionReplies: 2Last Post: 1st Feb 2008, 23:10 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
