  1. Hi.
    I have downloaded a film in mpeg format and would like to burn it to vcd.
    DivX is easy to encode and burn to vcd but, mpeg is a problem for me.
    Adaptec Easy...tells me I need to encode it, so I installed: MPEG-2 VIDEO VFAPI Plug-In.
    Now I try to encode it by using TMPGEnc and it seems to start up like any divX format.
    The problem is: it seems to be very halting when I look in preview like it only "capture" 1 frame/10 sek.
    And the time is more than 5 hrs.
    What to do?
    Anyone thanks.
    Stefan
  2. Banned
    Jun 2001
    UK
    Try this, it might help
    Select options > environmental settings
    click the VFAPI plug-in tab
    right click the "DirectShow" and select higher priority, do this several times until its at the top with a value of 4
    Did you load a VCD template ?
