Where can I get the size of the actual dvd disc and cover so i can design the artwork?
Thanks.
Later
You can check some cover sites (a list is on the site below) and see what sizes they use.
Panasonic DMR-ES45VS, keep those discs a burnin' -
Yep craig I thought of that right after I posted. It was a tuff one....
I just thought if they were easy to get hold of I could just fling it into illustrator and get going but its ok a ruler worked just fine.
Found some good stuff on the links though so thanks anyway,
later.
Request for measurements: 6MHz sweep response
By cybertheque in forum Capturing and VCRReplies: 5Last Post: 8th Oct 2008, 05:26
