Hi guys,
I just upgraded the firmware from 8.00 to 9.28 and afterwards performed the RC6 hack first with a Palm and then with the One4All remote control to make sure it was really changed (couldn't believe it was that easy ...).
Anyway, the DVD player works fine with DVDs and Audio-CDs, but it doesn't play VCDs properly. I see the picture but sound is not available at all. This was already the case before I upgraded the fw and performed the hack.
Is there anything else I need to do in order to get that bloody machine work? I just downloaded a sample file for SVCD and will burn a copy to try if that works (but I am not very confident).
Hope U can help.
Cheers
Hi,
How do you have your audio set up ?
I have a philips DVD player and have it hooked up to a surround amp via fibre optic and my stereo via regular audio plugs. To play (S)VCD's though my surround system I need to go into the players setup and change the audio to PCM / Stereo, otherwise my surround equipment won't pick up the signal. My player will send a stereo audio signal to my stereo no matter what settings I change.
Oh, BTW, make sure to change the audio settings back otherwise you won't get proper 5.1 output to your surround system....it will downmix to Dolby Surround (Pro Logic).....that is assuming, of course, that you have your player hooked up to a 5.1 system. -
:P
Hi bartman,
it works ... You saved my life! Thanks for your immediate response and your help.
Cheers
GetInTouch
Originally Posted by bartman
Help with Virtualdub and Pinnacle MovieBox 710-USB
By cgarai in forum Capturing and VCRReplies: 3Last Post: 7th Apr 2012, 01:14 -
DVP5992 Philips sound issue
By udidwht in forum DVD & Blu-ray PlayersReplies: 11Last Post: 21st Nov 2010, 22:58 -
Epson Artisan 710
By xobituaryx in forum MediaReplies: 2Last Post: 25th Feb 2010, 21:33 -
What is the best DL media for Pioneer 1810 and DVR-710 drives ?
By MacPCConsultants in forum MediaReplies: 9Last Post: 2nd Dec 2007, 14:37 -
Pioneer DVR-710 Question
By hollywoodfussell in forum DVD & Blu-ray WritersReplies: 12Last Post: 20th Aug 2007, 13:25
