after weeks of try to rempeg using rempeg2 without it crashing, i give up and used tmpgenc which worked, except when i remuxed it was out off sync, is there a way i can correct this problem?
I assume u r thrying to shrink the size to fit on a dvd-r. Rempeg id the best thing to do this with. If u r rusing XP pro try ending all non essential processes b4 u use repmeg as i had a similar problem and it worked fine after that. It's uses alot of system resources. As for correcting the outta sync problem see how much it is out of sync and try using the source range in tmpgenc and minus or puls the audio to what u think it is out by. But rempeg is best for making dvd9 to dvd5. Hope i helped.
Need help with sync problems during processing
By Jon.G in forum Authoring (DVD)Replies: 23Last Post: 6th May 2011, 04:14 -
problems with sync
By joachimfreitag in forum MacReplies: 5Last Post: 10th Sep 2009, 15:00 -
Audio Sync Problems
By Blue_3 in forum AudioReplies: 5Last Post: 10th Apr 2008, 18:17 -
Audio sync problems
By alvinboobar in forum Video ConversionReplies: 1Last Post: 10th Jul 2007, 06:22 -
Audio sync problems (again!!!)
By MadMaz in forum Newbie / General discussionsReplies: 10Last Post: 30th May 2007, 20:42
