Hi Folks,
I m a very regular User of Nero Burn....well I always wanted to burn a S-VCD....with Nero...so I tried the MPEG-2 plug in of NERO @ My office PC...and tried Burning S-VCD by the NERO Plugin...but Freinds...the sad Part if the Total Process was that Nero Burn took approximately 5-6 HRS only to ENCODE the VIDEO to MPEG-2 (SVCD Format), before Burning the S-VCD....
So Although I was successfull in burning one S-VCD in around 6.5 hrs on my HP-Cd writer Model--9140 i....But I ran out of energy in the Complete Process....also I dont see any difference in quality between a VCD and S-VCD while Playing it on my VCD-Player...
Can any one please suggest me a quicker and simpler method to RE-Encode my MPEG1 files to MPEG2...using the same NERO apparatus....
Any help or Suggestion will be a BOON for me...please HELP folks...
Meetu...
emailmeetu@rediffmail.com![]()
Best Regards form Meetu....
please don't post same post in several forums.
it is not possible to increase the speed of nero other than get a faster processor or wait for a new release of it.
have you tried any other encoder like tmpgenc?
are you encoding mpeg1 vcds to svcds? if so don't except any quality improvement, crap in crap out. -
How fast is your computer? Having a fast computer would boost up the speed a lot.
"Never trouble trouble, til trouble troubles you" -
Hi,
I agree..you must encode first with TMPGenc then run it through Nero.
I inadvertently ran a clip through Nero without encoding through TMPGenc first and found it takes an incredibly long time. Quality will also improve unless you are converting mpg1 to SVCD.
Good luck! -
reencoding vcd mpeg 1 to svcd mpeg 2 is of no use....quality is less....
one can make something that is not there...
always use source avi to convert to mpeg 2 and het a faster computer if you want is done quicker.
encode HD video 558% faster!!!
By deadrats in forum Video ConversionReplies: 4Last Post: 15th Apr 2009, 21:13 -
Computer question, what makes them encode faster, unrar faster etc.?
By willhenderson in forum ComputerReplies: 5Last Post: 30th Sep 2008, 22:21 -
HELP Burn using Nero Express doent work /but NERO VISION work fine
By STAR36 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 16:11 -
Encode mpeg-1 layer 3 in AVI to AC3 surround in Nero Vision Express 3
By jimbojr in forum AudioReplies: 0Last Post: 18th Feb 2008, 19:51 -
Nero FLAC plugin doens't work
By happydog500 in forum AudioReplies: 0Last Post: 4th Jun 2007, 13:07
