  1. I use Movie Maker to capture and edit, but it doesn't let you send it back to my DV camcorder. Would something like ATI All In Wonder Radeon 7500 do the trick? I also need an analogue capture card for capturing VHS, so is this the product for it?
  2. How do you get the DV video from the cam to the PC in the first place?
    As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
  3. I have a Firewire card..but the guide in the Movie Maker says that I'd need a 3rd party software to get it back to my DV cam...
  4. I personally use Adobe premiere to send back to my dv cam. You can also use scanlyzerlive....very inexpensive and great to use!
    Donald
  5. You need to make sure dv in is enabled on your camcorder. I know in the uk on a lot of cameras it is disabled to get around paying tax on it being a video recorder.
    Craig
  6. Is it possible to re-enable that feature, specifically on a VX1000 sony
  7. Yes it is usually possible, not sure about specifics for certain models, do a search on google for DV in enable.
    Craig
