i made a non-standard vcd videostream with tmpgenc 12h using sefy`s SeVCD setting and a 128kbs audio stream with toolame 0.12h.
then i muxed it with bbmpeg 1.23ß13 with the following program stream settings:
Program stream type: VCD
VBR: enabled
Write program end code: enabled
the rest is disabled.
the packet size is set to 2324 bytes, the mux rate depends.
when i want to build a .cue/.bin file with vcdimager it says:
++ WARN: mpeg stream will be padded on the fly...
++ WARN: autopadding requires to insert additional [...] zero bytes [...] (due to unaligned packets [...])
what should i do?
1. ignore it and let vcdimager do the autopadding (since on my dxr3 there is no problem playing the files, don`t know about standalone players!)?
2. change the bbmpeg settings and remux it?
thanks, ben.
Results 1 to 1 of 1
