MMC7.5
AIW 7500
latest capture drivers from ATI site
P4 1.8
512MB PC2100 RAM
80Gig 7200rpm HD w/DMA enabled
Using MMC7.5 to capture from VHS, I can capture MPG1 @ 720x576, 7.20Mbit/Sec without dropping a frame, but if i try to use Huffyuv to capture AVI I get on average 15 dropped frames per 30 minutes of video. Capturing at 352x576 will also drop about 3 frames per 30min of video using Huffyuv.
My CPU never goes over 52% load though (at 720x576) or 25% at 352x476.
I have tried iuVCR, VirtualVCR, and VirtualDub also...all drop frames (a little less with iuVCR, but still too many)
I thought it would be easier to capture AVI with Huffyuv than MPG1? Have I got this wrong? ive searched the forum and tried everything i can think of...but i cant figure out why im dropping frames. Might it have something to do with the way my hardware is set up??
I'm new to this still, so any help would be very much appreciated.
Results 1 to 1 of 1
prob joining VOBs; also sync prob with another movie
By spiritgumm in forum EditingReplies: 5Last Post: 19th Jun 2010, 09:32 -
operating system advice / bt878 / saa7134 / hardware config
By jafvid in forum Capturing and VCRReplies: 16Last Post: 23rd Mar 2010, 17:46 -
A hardware prob, but what?
By ahhaa in forum ComputerReplies: 3Last Post: 22nd Sep 2009, 21:00 -
ffdshow audio filter config
By THX-UltraII in forum Software PlayingReplies: 0Last Post: 17th Feb 2009, 03:12 -
Router config (D-link)
By SE14man in forum Newbie / General discussionsReplies: 4Last Post: 9th Dec 2007, 07:12
