I have DVD burner and some karaoke in vob files. I use ifoedit and nero to burn them. But Nero wont let me burn more than 10 vob files. It says it only support vts_xx_x.vob, not vts_xx_xx.vob.
for example:
vts_01_1.vob ---->vts_01_9.vob work
vts_01_10.vob and above will not work.
Is there any way I can put more than 10 vobs in on DVD? I wonder if I merge the vobs together, will I still able to move from song to song with the next button????
please help me out, thankyou very much.
btw you can do vts_02_1.vob
but i recomemd u use an authoring software so that you can have less vobs but have cues in the vobs so you can search easily -
Hi,
For each video stream there are a series of files like vts_xx_n.vob
In the filename the "xx" is the movie or video stream you want to play, and "n" is the next part of the stream. "xx" is between 01-99 and "n" is between 0-9....hence Nero telling you that you cannot have more that 10 VOB files. Each "n" portion of the VOB can be up to 1GB is size. If you were to utalise all this space, you should never reach the 10 file limit....not on a 4.7G dvd-r anyway.
Use something like SpruceUP or DVD Workshop.....both will let you insert "true" chapters into your project that you can use the "next" and "previous" keys on your remote to access.
Bartman... -
Thanks guys, but how can I put the vts_01_x.vob and vts_02_x.vob together on the DVD?
I used ifoedit. It only let me do one of them. -
1at make sure you have correct format mpeg-2 streams, and correct audio streams and subs. then bring them all into scenarist. author them together in the track editor and then place them in different PGC's in the scenario editor. scenarist will arrange them into the VOB's you need and the output should be fine to burn just like it is
Can VOB2MPG Pro combine VOBs from two disc into one mpg file?
By buzzworm in forum Newbie / General discussionsReplies: 1Last Post: 17th Mar 2012, 16:22 -
How to play multiple VOBs and a subtitle file
By kenj in forum Software PlayingReplies: 3Last Post: 22nd Jun 2010, 17:42 -
File output issue from TMPEnc Author Works, VOBs -> single MPEG2
By aln688 in forum Video ConversionReplies: 4Last Post: 10th Apr 2010, 20:17 -
How to cut VOB-file and create DVD from VOBs?
By john999UPR in forum Newbie / General discussionsReplies: 1Last Post: 19th Mar 2009, 10:07 -
Trim VOBs to re-burn to DVD
By ehmjay in forum MacReplies: 7Last Post: 16th Nov 2008, 16:59
