i am creating a VCD from a mpeg movie file and i am using a cdrw disk. i am wondering if i can use my erease my cdrw again after the vcd is created..
What option should i use? session-at-once, disk-at-once?
BTW, what program do u recommend?
thanks.
Stuff that I am not to sure about the quality of I burn to CDRW using disc at once....I watch it and if I'm not happy I just erase and use the disc for something else....If its something ya really like or just want to keep, use a CDR, they are a lot cheaper... maybe 10cent each in bulk.
All I ever use to burn is Nero, TMPG to encode first though. -
i use NTI.
Thanks.
So, i can use a CDRW to burn(test) the VCD. if the quality is bad, i can erase it... JUST TO make sure one thing
THE CDRW IS NOT FINALIZED(can be erased), RIGHT? -
I allways finalize...
CDRW can still be erased after that....You cant add anything else after finalizing a CDR or CDRW (not sure if VCD format would suport ...just adding more files any how)
How to create DVD disk using Pinacle studio 12
By 1234567 in forum Newbie / General discussionsReplies: 4Last Post: 30th Oct 2009, 11:32 -
Is there easy way to create Win2k boot disk with command prompt available?
By bevills1 in forum ComputerReplies: 9Last Post: 10th Apr 2008, 11:25 -
Won't create .img disk image
By LoafingOaf in forum ffmpegX general discussionReplies: 1Last Post: 13th Feb 2008, 10:02 -
How to create HD video on disk?
By mlong30 in forum DVD RippingReplies: 3Last Post: 28th Jul 2007, 16:00 -
Can't create DVD on DL disk HELP!
By mlong30 in forum Authoring (DVD)Replies: 2Last Post: 18th Jun 2007, 08:29
