ok guys I have a question for you experts out there.
Take this example: I have a 90 minute movie that I want to spread across 2 discs. I calculate that I can use a bitrate of 2200kb/s for video and 192 kb/s for audio. Now, I enter the following VBR settings into TMPGenc: average: 2200 min: 300 Max: 3500. After encoding I find that the file is 1.6 GB(800mb per disc). Now, because of the nature of VBR, more data is used in certain parts of the movie. So, there may be more data towards the end of the movie. This means if I split the video at 45 minutes the first part may be only 600MB and the second half could be 1000MB. I guess my question is how can I split the file based not on length but file size? I really don't want to reencode.
TV Respects Me!
You have to split it by filesize, the length will probably be the same anyway, it usually is for me, if you want equal length then you need to encode each disc seperately.
Span multiple discs with video?
By kruuth in forum Newbie / General discussionsReplies: 9Last Post: 27th Mar 2011, 10:56 -
Splitting bluray movie to 2 bd-r discs
By jayt34 in forum Authoring (Blu-ray)Replies: 4Last Post: 25th Jul 2010, 19:50 -
Multiple AVI files to multiple DVD discs, no quality loss, chapter per avi
By Delta007bhd in forum Video ConversionReplies: 11Last Post: 14th Apr 2010, 09:27 -
Splitting episode dvd to 2 discs
By parman in forum EditingReplies: 3Last Post: 12th Sep 2007, 17:05 -
I need help with splitting 21 video files on two discs.
By ombin in forum EditingReplies: 1Last Post: 19th Jul 2007, 22:02
