  1. where does the nemo codec pack install by default ?
    I installed it but I forgot to note the path/directory.Now I can`t find it,even with search function on my hard drive.
    After installation,do you have to do something (like opening and loading a file) when you need it or does the application automatically seek the nimo codecs when needed
  2. Banned
    Jun 2001
    UK
    The Nimo Codec pack is just a collection of the frequently used Codec's, the program will place the files in the correct locations like the system folder. Each codec it installs will be available in most editing programs, from them you can make any adjustments when using the codec.
    Coder & decoder Divx 4.12 Build 307 (Project Mayo)(divX).
    - Coder & decoder DivX V3.11a (3.11Alpha Low Motion)(Div3)
    for playing old compressed movies.
    - Coder & decoder DivX v3.11a (3.11Alpha Fast Motion)(Div4)
    - Coder & decoder DivX WMA Audio V4.2 (Standard)(divxa32).
    - Coder & decoder MPEG-Layer 3 Audio V4.2 (Professional)(l3acm), With control panel icon.
    - Decoder for AC3 Audio V2.2.
    - Coder & decoder MS MPEG-4 (For ASF/DivX Conversion)(mpg4,mp42,mp43).
    - Filters for Vob playback in Windows Media Player:
    MPEG Parser ActiveX filter
    MPEG Decoder ActiveX filter
    - MS-MPEG4 ActiveX filter
    - DivX V3.2 ActiveX filter
    - DivX V4.0 ActiveX filter
    - DivX AC3 Prologic ActiveX filter
    - The iviaudio.ax : InterVideo Audio Decoder ActiveX filter (No limit time)
    - The MS Mpeg Original codec (Microsoft)
    - The New MPEG-2 Splitter AC3 XForm
    - The New Ligos MPEG-2 Splitter 3.0.0.17
    - The Morgan Multimedia Stream Switcher (To change the audio stream in WMP)
    - I-Media Multi-MPEG2-Source
    - MPEG Layer-2 Audio Decoder
    - MPEG Layer-3 Audio Codec for MSACM
    - DivX AntiFreeze Filter (No more freezed movies)
    - DirectSound 3D Renderer (with help files)
    - Cyberlink PowerDVD 3.0 Audio Decoder
    - Ogg Vorbis Audio codec for MSACM
    - Lame_dshow.ax (Lame mp3)
    - Wavdest.ax
    - Dump.ax
    - Windows Media Audio Codec
    - Lame MP3 Encoder ACM Codec
    - 3ivx Delta 3.5 Codec for QuickTime Windows and the pluging for flask
    - Plug-ins for Flask: Panasonic MPEG 1, LSX MPEG 1 or MPEG2
    - The New Mpeg2dec DLL And the New Avisynth 1.05 MMX Dll for fast Frameserving
    - The New SimpleResize filter for Avisynth
    - The New Lame MP3 Encoder ACM 0.3.0
    - The New Directshow Bicubic Resizer 1.3
    - The New Playa 0.6.6
    - The New DivX AntiFreeze Filter 0.4
    - The New Sub Station Alpha v2.x/4.x
    - The New Moonlight Odio Dekoda
    - The New Moonlight Scalar Filter
    - The New Subtitle Picture Decoder
    - The New DynEQ DirectShow filter
    - The New DivX G400 Filter ver 2.7
    - The New DivFix 1.06 with Source Code
    - The Logo plug-in for VirtualDub and Nandub
    - The New Fraunhofer Vob Filters
    - The New Fraunhofer Mp3 codec
