I have used tmpgenc and vcd easy and a little virtualdub, And I was wondering what people are referencing in the forums when they say they are doing 2 passes.![]()
I know enough to be dangerous to myself.
http://www.research.ibm.com/journal/rd/434/westerink.html
Or, for a shorter version (for tmpgenc alone) that will leave you with unanswered questions:
http://www.vcdhelp.com/tmpgencexplained.htmAs Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
Thanks for the speedy reply. If I understand it right, You rerun the file through the tmpgenc twice??
I did read the links.
How to set MINIMUM bitrate in VBR 2 -pass on TMPGEnc Authoringworks 4
By eltimbomofo in forum Authoring (DVD)Replies: 3Last Post: 9th Mar 2012, 16:59 -
Technical Query Re Reading of 1st pass stats during second pass xvid encode
By onesikgypo in forum Video ConversionReplies: 1Last Post: 13th Mar 2011, 07:59 -
mpg file size smaller than expected, TMPGEnc 2.5 VBR 2-pass mode
By chipsndukes in forum Video ConversionReplies: 1Last Post: 22nd Dec 2008, 21:48 -
2 Pass VBR Problems in TMPGEnc
By Rez. in forum Video ConversionReplies: 0Last Post: 19th Dec 2007, 12:16 -
Cannot select 2 pass when wme 9 advanced profile is sel - Tmpgenc 4.0xpress
By vifa84 in forum Video ConversionReplies: 1Last Post: 4th Nov 2007, 13:22
