HI,
I got a vcd title .dat file. I tried to load with NERO, but it complained that it was not a MPEG-1. I tried using vcdgear and TMPGENC. Neither will not load the dat file. TMPGENC states that it was an invalid video file when I tried to re-mult to vcd format. When I load with MPEG-1 template, it stated that the file can not be opened or supported. I tried to load with Media Player. It states that there is not enough storage for operation on XP and no filter to render this stream on Win 2000. It onlys load and viewed with my WINDVD player.
Do I need a special codec? I would like to convert this dat file to MPEG-1 and burn to vcd with NERO. Anyone here knows how to do this, what others tools to use or codec to add to my win xp, and why it only plays with WIN 2000?
Thanks,
Rage
Results 1 to 12 of 12
try using vcdgear or just go to tmpgenc and use the cut and merge funciont and select the dat file as your source but dont split it and hit run itll work
here to help or express myself not to rack up my posts -
this dat file only loads with WINDVD...
When I to load with TMPGENC, it get an invalid video stream...or this file format is not supported message...
All vcdgear does is convert from dat to mpeg....
It does not convert it to MPEG-1 format...
Strange it will not load on Media Player or NERO....Only WINDVD...
Please respond if anyone has another option to re-mux to MPEG-1 format. -
Have you tried changing the file extension to mpg? Try that and then try to multiplex it using mpeg tools.
I have a similar problem - I have a .dat file that I want to convert to MPEG-1, but VCDGEAR generates 4 mpeg files - only 1 of which is playable but ony 25 seconds long. The other 3 files won't be recognised by anything with the 4th file being the one I need as the file size is about right.
When I try to use TMPGenc and the Merge/Cut option I receive just 1 small file, so I set the start point about 60 seconds in and receive the message "Illegal MPEG video stream". However, when I go to edit the start point I can press the play button and it will play fine!!
Any ideas from anyone??
Thanks,
Yoggit -
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
Thanks guys, but none of your suggestions work!!
I didn't realise that changing the extension to mpg was an option - I assumed that the dat file was in a different format...
banjazzer - when I try to multiplex, after about 1% of the input file is processed I receive the error "5 s packets cause buffer underflow. The MPEG file might cause error when it played".
As I mentioned in my previous post, vcdgear turns out 4 mpg files, 1 of which is of any significant size...but nothing I've tried will read or convert it to anything that's playable.
But, now that I know that I can just change the extension I've managed to play it in Windows media player, and as it turns out, my DVD player will play raw MPEGs (including this renamed file) so I don't have to try to do anything else with it :P
Thanks again,
yoggit -
As I mentioned in my previous post, vcdgear turns out 4 mpg files, 1 of which is of any significant size...but nothing I've tried will read or convert it to anything that's playable. -
i know how to solve this problem
u need VCDCUTTER
split da mpg into mv1 and mp2 with vcdcutter
then remultiplex it back with tmpgenc
2 easy man 2 easy
best format and size to convert a vcd dat file to for archiving?
By perfection in forum Newbie / General discussionsReplies: 3Last Post: 1st Apr 2012, 03:59 -
VCD Karaoke (MPEG DAT file)- removing the vocals
By tsrusa2002 in forum Video ConversionReplies: 12Last Post: 22nd May 2011, 02:51 -
How to corp a dat or mpeg file to mpeg
By onlyrasel in forum VCDEasy GeneralReplies: 1Last Post: 26th Sep 2008, 23:18 -
Empty file when converting vcd (.dat) format to ipod (mpeg4)
By happyriceman in forum ffmpegX general discussionReplies: 3Last Post: 5th Jul 2008, 05:19 -
converting .DAT file to readable jpeg
By illyad in forum ComputerReplies: 4Last Post: 23rd Oct 2007, 04:14
