Hello, i am very new to all this, i have tried burning with nero, version 5.5.9.. it has taken me twice over 14 hours to encode so it says at the the top, in the end at 82% encode i gave up, and stopped it.
am i doing something wrong, i did not expect to spend that length of time to encode , and after encoding does it burn the film, or it that the whole process.
thanking you all in advance for any help![]()
Dont use nero to encode anything. There are a lot of free encoders
on the net that give you great results use one of them to encode your movie first and nero to only burn it at the end.
pop over to doom9.net he has all the software you need and some
easy to use guides on how to make your movies.
http://<a class="contentlink" href="http://www.doom9.net/" target="_blank" rel="nofoll...<br /> spyda. -
Thanks Craig you are right!
The Guides on this site are also great
appolies all round
spyda -
Thank you for your replies..
As i stated in the title i am totally new and i cannot understand what it is i am meant to do.
i went to the doom9 site.. and wow. right over my head.
please forgive me, but the newie nieve title is on my head........
anyone can explain in a more laymans terms.
thanking you all for your time
You need only 2 basic programs
1, Vdub
http://www.virtualdub.org/
2, TMPGEnc
http://www.tmpgenc.net/
Vdub can be used to edit your AVI's, it can also be used to remove junk frames, and save out the audio if needed.
You then use TMPGEnc to convert the AVI to a Mpeg 1 (Load VCD template) PAL or NTSC
Now you can use the .mpg with Nero VCD
AutoMKV - am I doing this wrong?
By Phat J in forum Video ConversionReplies: 2Last Post: 2nd Dec 2010, 02:50 -
What's wrong with Sub2DivX!
By kehn in forum SubtitleReplies: 4Last Post: 27th Dec 2008, 11:21 -
What did I do wrong???
By olofen in forum ffmpegX general discussionReplies: 1Last Post: 12th Jul 2008, 09:36 -
Where did it go wrong?
By video_enthusiast07 in forum Authoring (DVD)Replies: 1Last Post: 31st Dec 2007, 18:17 -
OK, what's gone wrong here?
By EddyH in forum Authoring (DVD)Replies: 6Last Post: 30th Jun 2007, 04:11
