I want to convert a 23.976 fps DivX movie to 25 fps VCD
Without TMPGEnc jumping and adding frames.
Anyone who knows how???
Personally, I'd use VirtualDub to change the frame rate, and re-sample the soundtrack to the appropriate length.
What you're trying to do is bascially the same as what's done when films are transferred to PAL. They show every frame once, but up the rate from ~24fps to 25 fps. Films are therefore about 4% shorter when you watch them on PAL.
Matt... -
Matt... -
I extract the audio as a WAV file, and use CoolEdit to speed it up. I use a small program called AVIFrate that patches the AVI frame rate - that way you don't have to frame serve with VirtualDub....
To synchronize 29,970 audio fps for 23.976 fps
By DruidCtba in forum Newbie / General discussionsReplies: 1Last Post: 27th Sep 2009, 13:01 -
Sync 29.970 FPS audio to 23.976 FPS video?
By LCO1971 in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2008, 16:23 -
Difference between 23.976 fps and 23.98 fps ???
By wasimismail in forum Authoring (VCD/SVCD)Replies: 5Last Post: 27th May 2008, 01:42 -
Converting 23.976 fps to 29.9 fps
By zanos in forum Video ConversionReplies: 4Last Post: 13th Apr 2008, 10:03 -
20 fps to 23.976 fps Questions
By Maikeru-sama in forum Video ConversionReplies: 39Last Post: 27th Aug 2007, 10:16
