I have a few PAL VCDs that I bought overseas. I used TMPGEnc to convert it to NTSC format. But when I use Easy CD Creator 4.02 to burn onto CD and try to view it on the DVD player, I find that the VCD doesn't automatically play. Instead I have to use the remote control to navigate to that folder and file, then click play. I have an Apex 5131 DVD player. When creating the CD, I simply copy all the files/folders from the original PAL VCD and replace the .DAT files in the MPEGAV folder with the converted TMPGEnc output files.
How do I burn a CD such that it just automatically plays on my DVD player? Do I need to used something like VCDEasy? or Nero? or do I just use a different setting in EasyCD Creator?
Thanks.
Ken
Does your player have a PBC on/off option in the setup?
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
First: Are you using Easy CD Creator instead of Video CD Creator? If so, you're probably creating a data CD with a VCD's structure, not a true video CD. You have to have the retail copy of Easy CD in order to get VCD Creator.
If you don't have Video CD Creator, then I'd strongly advise you to download the trial version of Nero and use that instead. Use its VCD template and drag your files to it.
My DVD player doesn't auto-play VCDs, so I can't be sure Nero will make an auto-play VCD, but I have software that auto-plays VCDs on my computer. It works for disks I've created with Nero.
If you DO have Video CD Creator, then just load your converted files into it and let it do its thing. It will check the files for VCD standards-compliance and put them in the proper directory. -
Ah, yes, "VCD" doesn't just mean a VCD-conpliant MPEG file on a CD, it means a VideoCD-compliant disk, with this structure:
http://users.evitech.fi/~arndb/project/htmlmain/node15.html#SECTION00744000000000000000As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
Sony DVP-NC665P - Cannot Play DVD's Consecutively Automatically
By searchlight in forum DVD & Blu-ray PlayersReplies: 1Last Post: 12th Feb 2011, 00:21 -
VCD cannot play in PC but can play in DVD player
By avatar123 in forum Authoring (VCD/SVCD)Replies: 28Last Post: 3rd Jan 2011, 16:32 -
Video from PC encoded and Burnt to VCD to Play on my DVD R Player
By dashas in forum Video ConversionReplies: 3Last Post: 16th Jul 2010, 21:15 -
DVD - How do I make all files play automatically?
By gina_here in forum Authoring (DVD)Replies: 7Last Post: 4th Aug 2008, 14:25 -
Media Player Classic won't automatically play the next MPG in a playlist
By dmcmurphy in forum Software PlayingReplies: 0Last Post: 4th Jun 2007, 18:19
