I just bought and installed a hp dvd writer 200i, I use a hollywood dv bridge from dazzle to capture. I captured about 30 min of a store bought dvd using the software supplied with the burner (sonic my dvd) and burned it with that also, seemed to work pretty well. I have read what seems like many posts on this site that the hp software is not very good, what is the most recomended software for capturing, editing, and burning? I have just captured a movie from my svhs, it is in the avi format of course, what is the best converting software to convert this to mpeg2 or what ever the highest quality format I can use with my dvd burner? The dvd burner media is dvd+r, dvd+rw, cd-r, cd-rw. As you can tell, I am just getting started, any input would be great, thanx in advance.
Results 1 to 1 of 1
K-Lite Codec Pack messing up burning IMG audio cd burning
By Blå_Mocka in forum AudioReplies: 24Last Post: 26th Aug 2010, 06:27 -
1. Need advice: Burning DVD from Flash Drive mP4 2. DVD-R vs. DVD+R
By Ronald Vaughan in forum Newbie / General discussionsReplies: 1Last Post: 14th Jul 2010, 15:53 -
Iso burning faile, folder burning succeed
By cd090580 in forum DVD & Blu-ray WritersReplies: 5Last Post: 3rd Dec 2009, 15:46 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Advantages - disadvantages to burning video folders or burning an ISO img
By theewizard in forum Authoring (DVD)Replies: 14Last Post: 26th Jun 2007, 16:19
