Hi everyone,
I'm confused about which program to rip from my dvds. For instance I am doing The Fugitive and in Smarttipper there are 3 programs - one is 2:10, four is 1:50 and 5 is 2:04 (the ones in between are small). I ripped one, but I started to rip 4 and 5 and they all start ripping the vts_01 files. I noticed the same thing with Independence Day - it looks like seeveral versions with different sizes.
What is the difference between them and how do I know which to rip?
Thanks,
Deb
smart ripper is whaat i used to cut my teeth in the dvd rip game, but i moved on, vstrip is probably the most versatile, but overall it's tough to beat dvd decrypter. get it and use this http://www.doom9.org/dvddec.htm
Thanks for the replies.
I have DVD Decrypter, but it seemed pretty similar to Smartripper from an inexperienced eye (the kind that just memorizes a few steps that get the job done).
What an excellent guide! I should be able to get a better understanding of what I'm doing. I'll give it a try for my next rips.
The instructions say that it writes to DVD - have you ever tried it for that?
Thanks!
Deb -
yes it will burn dvd image files. you have to first have an image to input though. i suggest making your image with ifoedit and the imagetools plug in or just omagetools by itself
Program to rip chapters to M2TS, other than DVDFab?
By kernunrex in forum Blu-ray RippingReplies: 6Last Post: 1st Sep 2012, 15:38 -
Another program to rip subtitles to pdf apart from Xilisoft?
By Talayero in forum SubtitleReplies: 0Last Post: 12th Jun 2009, 07:15 -
What's the best-easily working program to rip sound from vcd ?
By billyww in forum AudioReplies: 1Last Post: 20th Jan 2009, 06:30 -
Best program to rip dvd's to Mpeg4 for iPOD
By Jabroni4872 in forum DVD RippingReplies: 3Last Post: 21st Oct 2008, 11:47 -
DVD rip Program that Utilize all 4 cores???
By ttt0649 in forum DVD RippingReplies: 14Last Post: 17th Dec 2007, 16:09
