I am trying to conver AVI's downloaded from the net into MPEG's to rip unto VCD but doesn't work. I got into the Video source and attempt to load the avi file but all I get is C:\v.vi can not open, or unsupported.
What am I doing wrong?
What is the format (e.g. DV,DivX) of the film inside the AVI?
AVI is only a fileformat which can hold video encoded with different encoders/algorithms like DivX and DV. You must have a decoder to be able to encode the file in TMPGEnc.
Can you watch the AVI on your computer, in that case you do have an decoder installed. -
The files are primarily DivX.... Did not know about the whole decoder thing - I am pretty sure that would be the problem. How would one go about getting a decoder and installing it for the TMPEnc to work.
- Kwaj -
For DivX I'm using the de- and encoder that is available at www.divx.com/. I'm using the latest beta version which works great for me.
how do I install x264.exe to work AND to work with Lemings GUI?
By Krelmaneck in forum Newbie / General discussionsReplies: 1Last Post: 14th Nov 2010, 22:13 -
TmpGenc Authoring Work Shop 4
By pepegot1 in forum Authoring (DVD)Replies: 0Last Post: 1st Apr 2010, 18:43 -
HELP Burn using Nero Express doent work /but NERO VISION work fine
By STAR36 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 16:11 -
How much do you work? (work = doing something you are getting paid for)
By Baldrick in forum PollsReplies: 20Last Post: 26th Nov 2007, 15:35 -
Does TMPGenc Plus 2.5 work on Vista Ok?
By leegutcher in forum Newbie / General discussionsReplies: 1Last Post: 6th Jul 2007, 07:22
