I have converted a couple of avi files to mpeg here and they are now the size of 1.2GB, so i have been trying to find out how to split them into two files here so they can fit on two cd's....i know this might be a very stupid question, but pls anyone...help me out....
I have tried the TMPEGnc, but i can't seem to undesrtand what the hell it's doing.....tried to set the start and end point....but...i have no clue waht to do here.....pls anyone..????????
As you are probably already in the Merge & Cut process, it is relatively easy.
You load the original file with the Add button.
Name the new file name of the first file you will make.
Select Edit. When the new window pops up, select the Start and end points.
Select ok. When the program returns to Merge & cut window, your old file has new times on it (the start and end times you just set).
Select "Run". The program will now create the first file containing the first half of your original file. It will be named the name you gave it in the third step.
Repeat this procedure for the remaining part of your original file -- Voila!Hello. -
Originally Posted by Sepiroth
File > Mpeg tools > Merge and Cut
Also change the drop down arrow to "MPEG1- Video CD" The two parentheses brackets can be used to mark start and end {start } end Moving the slider to the end will show you the playing time.
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2018, 19:16 -
Having problems trying to split MPEG-4 file
By Xax in forum EditingReplies: 7Last Post: 4th Dec 2009, 16:27 -
how to split contents of VIDEO_TS file to fit on CD discs
By strychnine81 in forum Newbie / General discussionsReplies: 14Last Post: 2nd May 2009, 09:03 -
Best way to split an MPEG file is to ???
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 7Last Post: 10th Mar 2009, 20:31 -
Split Mpeg or convert to AVI then split. What to do?
By oldfart13 in forum Video ConversionReplies: 4Last Post: 24th Mar 2008, 00:00
