Hi there i have been following a guide from nickys pages for DIVX ripping i have done the Video, now i want to do the Audio following his guide using Graphedit The problem is i need a program called REGDROP, the link on his site is to the makers and its dead) i have searched through about 30 software sites AND THEY ALL link to the same site which is dead, i have tried E Donkey, Kazaar etc you are my last hope has anyone got the program called Regdrop so i can complete my rip?
Thanks in advance
MAC
What exactly does REGDROP do?I never encoutered the name so far with GraphEdit.If you need this for registration of filters, you can use regsrv32 (or something like that).
I am using this guide
http://nickyguides.digital-digest.com/audio-extract.htm
basically it says regdrop is needed to resgister somefiles?
it says:
Put GraphEdit in a folder somewhere and register all the filters with RegDrop
i am desperately trying to encode my audio so any help would be appreciated.
I have also heard of that other program you mentioned and again i cant find it anywhere all links seem to be dead does anyone have any program which i can use for registering? (and can send to e mail?)MAC -
Don't worry, regsvr32 will do this job for you(as I suspected).
Just call regsvr32 <filter-name> and you're done.
Maybe you need the Audio file filter (this is only as source in the SDK).
It's called wavdest.ax.Mail me, if you need this.
do this (under cmd)
regsvr32 wavdest.ax
program
By maxone71 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 30th Oct 2011, 05:23 -
Better Program?
By electrowiz in forum Newbie / General discussionsReplies: 1Last Post: 16th Mar 2011, 18:28 -
What's the name a program? unkown program
By Andrey81 in forum SubtitleReplies: 1Last Post: 26th Jan 2011, 12:04 -
MKV to AVI program, hardsubbing program, adding subtitle to DVD Flick
By projecttemp in forum Video ConversionReplies: 1Last Post: 21st Sep 2009, 08:42 -
Which program should I use?
By Belfour in forum DVD RippingReplies: 6Last Post: 26th Jun 2007, 08:54
