Please reply if you are an expert in do this.
DONT YOU DARE THINK OF USING ASF!!!!!!
Once you get the file converted to ASF, it will look like crap and you can't decode it back tto AVI.
I would make a DVD with MPEG 1 video at vcd resolution. I would then obtain a DVD-/+Rw and play with the bitrate to see what the max bit rate I could go with.
It's best to put them on DVD-R because it's the highest quality and has alot of compatibility. It might be expensive, but their backed up in good quality. -
U are right but I don't know why I have this thing of wanting to have all my VHS in ASF.
Oh why does no one vote in my poll vote? -
if you are serious about archiving your old vhs footage
then consider one of those top of the line JVC svhs with built in TBC with 4MB digipure memory(fixes jitters and other ills that old tapes have) and use that to play them while using a high quality video capture card to capture from the JVC and encode to mpeg2 2 highest bitrate and burn onto dvd-r if you have the money for all that
just my opinion -
If you don't have to edit in any way, get a standalone DVD-R recorder like the Panasonic E20 or E30. Easy then to transfer them to DVD in real time. Cheap disks like Vivastar work just fine with that.
Option #1 or #3.
After you get done with the transfers, put little hats and lab coats on the VHS tapes, grab a camcorder and film an Indie movie where the evil cassette aliens kidnap household pets and perform experimental surgery on the little buggers, turning them into terrifying cyborg killing machines that speak with voices that sound like electric guitars. The tape aliens use their evil cyborg creations to almost take over the world but are defeated in the end by a mutated version of the Powerpuff Girls that look like fat little Rosie O'Donnells, which stop to eat sides of beef on a frequent basis and go through lots of toilet paper afterwards.
That's just a rough concept, so modify as you see fit.As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
Here's a little promer on claymation, which you might find useful for constructing some of your film "characters".
Restoring old VHS and Hi8 captured videos with Premiere
By alegator in forum EditingReplies: 1Last Post: 4th Oct 2010, 06:07 -
Remove Noise from VHS Videos
By abazabam in forum RestorationReplies: 12Last Post: 23rd Jun 2010, 13:04 -
transferring vhs videos from vcr to computer
By dvdnewbie64 in forum Newbie / General discussionsReplies: 9Last Post: 25th Feb 2009, 00:17 -
Recent home videos (VHS) recorded to DVD & now in Mpeg2...
By tehfreeman in forum DVD RippingReplies: 7Last Post: 19th Dec 2008, 14:12 -
Should I restore vhs videos?
By Grace's Mom in forum RestorationReplies: 5Last Post: 19th Aug 2008, 23:24
