I tried a C-Media cmi8738 sound card and it always embeded hiss in the audio of the video captures.
The sound volume was also very low.
I have an old SB Live value that does work, but I'm starting to worry about driver support.
The last drivers released for it was 5/5/00 and they aren't WDM drivers.
I'm almost positive that any lockup I ever have is due to the live.
Any suggestions, esp in the < $50.00 range
Trik
bump ^
Come on folks, I'm not asking for bank acct info.
I'm asking what sound card you use
SBLive! Value, and the drivers that Windows XP online update installed are WDM (5.1.2602.0) drivers.
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
I'm still using win98se and there aren't any wdm drivers for it that I know of. -
SB Live owners should deinstall all the extra creative apps and control
panel utility (as well as dos plug&play compat driver) and keep just
the basic drivers. You should then capture at only 41.1Hkz 16bit. This can prevent many of the lockups and sync issues some have reported. -
The best choice for a sound card in that price range is going to be a Turtle Beach Santa Cruz, MUCH, MUCH better than the Sound Blaster Live! cards, and MUCH more stable. This is also the sound card that ADS tells users to buy to try to make the ADS Instant DVD work better.
What is the best virtual surround sound from a motherboard or a sound-card?
By MarcMiller in forum ComputerReplies: 0Last Post: 19th Jan 2012, 22:03 -
[VHS conversion] Sound Card, Video Card?
By bessiecat in forum Capturing and VCRReplies: 6Last Post: 26th May 2011, 14:02 -
What are the downsides to having both onboard sound and Sound Card enabled?
By c627627 in forum Capturing and VCRReplies: 0Last Post: 21st May 2010, 15:44 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 17:13 -
NEW sound card + NO sound ???
By blinky88 in forum ComputerReplies: 8Last Post: 17th Jun 2009, 11:30
