I have this AVI file that no matter what program I use it always has an error when I use TMPGEnc it act like it is way to big, but then I can go into the select range and set the end frame(to the actually end frame) which shrinks it, but then I have this really long number error. I have also tried using DVDit PE which just give me a unknown error please HELP!
TMPGEnc doesnt care how big your files is .. but what IS the error you are seeing - it may help to know ..
Did you happen to get the file from a P2P network? If so, you should accept the possiblity that you may never be able to get this file to behave properly, but just to be sure:
Make sure you have all the latest codecs that relate to this type of file. If you can't play it, you can't encode it. This is the only solution I can think of.
If, on the other hand, you produced this AVI yourself, how so?
How to convert DV avi files to DVD ready MPG files with Win7 powershell.
By findus in forum User guidesReplies: 5Last Post: 19th Dec 2011, 16:42 -
How to quickly split M2TS files just like AVI Splitter works with AVI files
By hoovey1969 in forum EditingReplies: 1Last Post: 30th Nov 2009, 22:42 -
How do I put AVI files onto a DVD as AVI files?
By dgarmaise in forum Authoring (DVD)Replies: 15Last Post: 17th Mar 2008, 20:32 -
Is it doable to convert HDV/.m2t 1080i files to AVI files and what...
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 4Last Post: 30th Sep 2007, 04:03 -
whats best to use to copy my home videos to DVD... avi files or wmv files??
By leegutcher in forum Newbie / General discussionsReplies: 5Last Post: 14th Jun 2007, 04:24
