I'm wondering if it is possible to have a 2nd audio track that you can switch on before watching a movie. I want to do director commentary kind of stuff. Is it possible?
Svcds support 2 stereo audio tracks or 4 mono ones.
You can create two audio tracks, say the main audio and the director's commentary track, and multiplex both in with your audio. You can use the multiplex option (not simple multiplex) in TMPGenc's mpeg tools, bbmpeg, or I-Author to do this.
You will then be able to toggle between the two audio tracks during playback by hitting the audio button.
Two audio tracks playing at the same time?
By churchie04 in forum DVD & Blu-ray PlayersReplies: 11Last Post: 9th Apr 2012, 22:34 -
Playing MKV with multiple audio tracks - does it load computer more?
By tufffta in forum Software PlayingReplies: 6Last Post: 4th Mar 2012, 17:44 -
Dual Audio Tracks Playing After K-Lite Codec Pack
By Boris_yo in forum Video Streaming DownloadingReplies: 9Last Post: 7th Jan 2011, 06:57 -
bizarre bug - DVD tracks playing in wrong order in DVP5990/92
By lhughes in forum DVD & Blu-ray PlayersReplies: 1Last Post: 22nd Aug 2010, 04:23 -
Video with L/R tracks to DVD with 2 channel audio tracks
By Downloader in forum Authoring (DVD)Replies: 2Last Post: 22nd Aug 2010, 01:56
