I'm running Win2K, Cybermail PCI BT848 capture card with generic WDM drivers. I know the field order is the opposite from normal with this card, but there is another annoying problem. When capturing less than 480 horizontal pixels, the line numbering is reversed! The field order is OK, but the lines in pairs of two have swapped position. It's like the horizontal lines are 2,1,4,3,6,5 but it doesn't help to swap the field order. It ONLY happens when capturing less horizontal pixels than vertical pixels, so 480x480, 640x480 and 720x480 are fine, but 352x480 has the wrong line numbering. Anybody else seen this problem, and found a fix for it?
